zafer
Oct 09, 2008cache rule for different age and uri
Hello
here is my code
if { [ matchclass [HTTP::path] ends_with $::cache_obj] or [ matchclass [HTTP::path] ends_with $::images] } {
CACHE::enable
log local0. "Caching [HTTP::path]"
CACHE::disable
log local0. "Non Caching [HTTP::path]"
i want cache images 30 days
.css 15 minutes
.js or url contains get_categories or contains serach.php? 30 minutes
i dont want cache all other domains and
what do i need to change in my config and http profile
zafer
- hoolio
Hi Zafer,
You can check the cache wiki page (Click here) for details on the commands. It looks like you can get the age of the cached object using CACHE::age. You can expire a cached object using CACHE::expire. You can view the cached objects from the command line using 'b profile http HTTP_PROFILE_NAME ramcache entry all show'.
I ran into a bug on 9.4.5HF2 when explicitly enabling caching in the HTTP_REQUEST event of an iRule. If the request doesn't contain a host header and the request matches the test to explicitly force caching with CACHE::enable, TMM will crash. F5 noted this in CR108998. The workaround is to either check for a host header, or more ideally, let the caching be enabled in the HTTP profile and then selectively disable it when your caching criteria isn't met.
Aaron - zafer
is that possible to help me writing this code, i have no experience cache issues.
i tried some parameters for expire event in irule but i didnt solve my problem
zafer
