alirizaaydin_38's avatar
alirizaaydin_38
Mar 22, 2019
Bits in/out difference
Hi..
Although the two pool members have the same number of connections, why are the bits in and out values different?
  • Hi,
    so find below the difference:
    In: The sum of all ingress traffic Out: The sum of all egress traffic
    the size difference between incoming and outgoing packets is normal because the server response is much larger than your request.
    for more details:
    https://support.f5.com/csp/article/K9932
    Hope it's clear. let me know if you need more details. regards,
