greg-_32923
15 years agoBIGIP VE 10.1.0.3341.1084 issue application octet/stream
Hello,
i am having an issue while opening virtual server webpage on windows O/S in every web browser.
I have defined pool , pool member which is listening on port 81 and virtual server which is listening on port 80. I gave only 1 pool member. Virtual server points to a pool member on which apache is running with coldfusion server.
When i connect to pool member directly i can access the webpage ( under windows and linux ).
I have set snat : automap . i got 2 client pc virtual machines that are connecting to virtual server.
When accessing the virtual server from a linux OS using firefox webpage is generating without any issues.
When accessing the virtual server from a windows OS using firefox/chrome/opera/IE , webpage is empty (in IE/opera/chrome), and when i try to open it in firefox it asks me what do i want to do with the Application octet/stream . When i choose save to disk, and open the file, there is no html code.
What i really do not understand is that i managed to get it working with 1 trick... On the F5 ltm VE console, i issue command : tcpdump on internal interface , and from windows OS the webpage is accessible. I really do not have any clue why it is starting to work after i run tcpdump from big-ip VE virtual machine.
In apache logs while browsing using linux i got normal queries and answers. When browsing with windows in apache logs i see this:
* . * . * . * - - [date] "" 501 293 ""-"" "-"" .
i really do not know how to connect things like "it works when tcpdump is working" with the issue. Did anyone have any issue similar to mine ?
Regards,
Greg
- hoolio
Hi Greg,
Can you use Wireshark or tcpdump on the VM host (not on LTM VE) and compare the working scenario from a Linux client with the failing request/response from a Windows client? Check to see if there is anything different in the response headers or content and then the request headers or content.
Aaron - greg-_32923
I made screenshots from wireshark on windows
1) while tcpdump -i internal is working
http://s1.img.pl/v/7011/winok.jpg
2) while tcpdump -i internat was not running
http://s1.img.pl/v/7017/winfail.jpg
And a screenshot from linux without having tcpdump turned on on big ip
1) http://s1.img.pl/v/7023/linuxok.jpg
