thagmann_128177's avatar
thagmann_128177
Oct 21, 2004
BIGIP Model #'s - Is there a Unique Key?
F5,
We need to be able to distinguish our BIGIP Model 's from each other (Ex: tell a BIGIP 5100 vs. a BIGIP 6400) and we were wondering 2 things:
1.) How could we best accomplish this using iControl v9.0?
2.) How could we best accomplish this using SNMP? Is there a given OID you recommend that is unique to each model?
The reason I ask is that usually our Tools Team uses the sysObjID to distinguish between platforms from other vendors and they mentioned that they saw the same response for a BIGIP 5100 running 9.0 that they did for a BIGIP 6400 running 9.0. Perhaps there is a better OID we should be using though.
Thanks,
-Tom
  • 1. How could we best accomplish this using iControl v9.0
    In v9.0, we added the platform to the SystemInfo structure
    struct SystemInformation {
               String system_name
               String host_name
               String os_release
               String os_machine
               String os_version operating system.
               String platform
               String product_category
               String chassis_serial
               String switch_board_serial
               String switch_board_part_revision
               String host_board_serial
               String host_board_part_revision
               String annunciator_board_serial
               String annunciator_board_part_revision
     SystemInformation System::SystemInfo::get_system_information();
    You are looking for the platform member of this structure. For those interested with the 4.x platform, you can use the ITCMLocalLB::Global::get_system_type() method.
    I just verified with our SNMP developers that we currently do not expose the platform type via SNMP.
    -Joe
  • Joe,
    Glad to see it is iControl. I may have to follow up with the SNMP guys on it as well.
    Thanks for the help as always,
    -tom
