francisco_1_162's avatar
francisco_1_162
Apr 14, 2011
BIGIP MGMT Interface DHCP
Simple question, on the cli i can use config ultility to setup static IP but not to setup mgmt interface to use DHCP. How can i setup mgmt interface to use dhcp. I know i could use the LCD panel but i need to do it fom cli access since i do not have physical acess to the unit.
Thanks in advance
  • hoolio's avatar
    hoolio
    You can do this in the GUI under System | Platform | Management Port Configuration: Automatic (DHCP). From the CLI, you can use:
    view: b system mgmt dhcp
    enable: b system mgmt dhcp enable
    disable: b system mgmt dhcp disable
    Once you've made the change, run 'b save all' to write the change from memory to disk.
    Aaron
  • hoolio's avatar
    hoolio
    For your reference, I found that by running 'bigpipe help | less' and searching through for "dhcp". That's a useful way to search all bigpipe command options when you're not sure of the exact syntax.
    Aaron
  • Leroyfli_107479's avatar
    Leroyfli_107479
    Historic F5 Account
    This has gotten a little long in the tooth for TMSH use the following:
    modify sys global-settings mgmt-dhcp enable
