flypast
Altostratus
Nov 23, 2010BIGIP LTM VE 10.0.2 licence issue
I am installing VE 10.0.2 on the ESX 4.1i. Installation is successful. But when i try to use the trail registration key to get the licence, F5 web site shows the following alert:
Unable to grant license key: Error 51133, F5 registration key is not compatible with the detected platform - This platform
I can see two possiblities:
(1) 10.0.2 doesn't support ESX4.1i
(2) Trail key doesn't work for VE10.0.2
It is highly appreciated if anybody can advise the reason why i can't get licence.
Thank you very much!
- qe_102628
The BIG-IP LTM VE Trial Edition is 10.1.0 based. Your LTM VE Trial keys will only work with this version.
You can download it from http://www.f5.com/trial - Ramy_Al_Damati_
i face the same issue , in the trial link is give you only the license for the version 10.1 not for the 10.2
can any one help us in this issue ?
Thanks - hwidjaja_37598
Altostratus
There is no free trial license for 10.2. It's only for 10.1 at the moment. - kev_245_28249
I don't blame the confusion it is not very clear. The download link for the trial takes you to a page where one can simply reselect to a higher or lower version.
I think this is where the confusion is created. - azlan_7649
the website said "Unable to grant license key: Error 51133, F5 registration key is not compatible with the detected platform - This platform" after i paste the dosier...i'm using trial key...
BIG-IP 11.1.0 - hoolio
Hi Azlan,
I don't believe there are plans to support any new trial versions other than 10.1.0. If you want to try out a more recent version, you could ask your F5 SE or partner to give you an evaluation key.
Aaron
