big ip ltm persistence help
folks
i have a couple of ironports in a pool behind a vserver on my ltm 1600 and they're giving me problems with authentication
i've configured source address persistence (/24 mask) and bound it to the vserver
when i use the ltm as my explicit proxy i can connect from device A and all the traffic goes to a single ironport
if i connect from device B i'm passed to a different ironport but can't get internet access - if i tail the acesslogs on the ironport i can see a http 307 but no traffic is passed
i'm looking for advice on
how to correctly configure a persistence policy
how to verify that policy is being applied
thanks to anyone lookin at this or replying
- Approxee
try this command "show /ltm persistence persist-records" in TMOS, or you can view it from the statistics part of the web interface - StephanManthey
Nacreous
You are sure the issue is related to persistency? Your described approach should make sure a specific mapping will be made based on the clients network range of 24bit.
How about taking one of the proxies offline (individual poolmember settings) and run tests again from both clients? Still same result? Now switch the proxies and try again, please.
Do you see the 307 as well for logons from client A? How does the client B deal with the 307? A and B belong to different subnets? Otherwise they should be send to the same poolmember according to the selected persistence method. A browser plugin or a clientside tcpdump on your BIG-IP may help to troubleshoot the issue. - mulhollandm_648
greecemonkey many thanks for your help i ran the command but i get 0 records even though i can see the traffic staying with one ironport thanks
