big ip ltm not passing https traffic
folks
i have a ltm 1600 which has stopped passing https traffic to an upstream proxy farm
user traffic is sent to the vserver ip on the ltm on port 8080 and then onto the proxies (a persistence profile is being used)
ssl was being passed ok but someone has reconfigured something on the f5 and i'm not sure where to start looking or jhow to troubleshoot
can anybody help?
ps - the proxies are processing https traffic ok if i hit them directly and it looks like a https request via the ltm doesn't reach the proxy
thanks to anyone helping out
- What_Lies_Bene1
Can you post the VS and Pool configurations please. Use
to obtain the text configuration.tmsh list ltm virtual | pool ... - mulhollandm_648
thanks for your response
i was getting together the info you requested when i noticed soeone had added an request logging and an analytics profile
once i deleted both these from the vserver it now works
not sure why or these do but i'll do some research
thanks again
- What_Lies_Bene1
Interesting. I wonder if it's worth adding them back individually to understand which one is the issue. From there, you can check the profile in detail and see what's wrong.
If you're not actually terminating the SSL on the F5 I'd imagine it could actually be both. You can use an Analytics profile with that setup but it can't be configured with to monitor HTTP.
