ask_me_anytime_'s avatar
ask_me_anytime_
Mar 03, 2008
BIG-IP LTM 1500 does not boot !!! please help
hi,
I have got a problem with my BIG-IP 1500 system.
the BIG-IP was working fine with v9.3.1 and
I was doing a version downgrade to BIGIP V.9.1.2 (clean install ) , when the BIG-IP exited the installation process and came back to the shell prompt.
i rebooted the system from that prompt but the BIG-IP would not boot anymore to the pre-installed OS.
I get the below error message on the console :
--------------MESSAGE BEGINS HERE---------------
System is booting, please wait...
Press Ctrl-c to stop autoboot: 5 4 3 2 1 0
kernel.core_uses_pid = 0
kernel.core_pattern = /var/core/%e.sccp.core
Host Console Shell --- Press ( for command menu.
-------------MESSAGE BEGINS END ------------------
The BIG-IP system stops at the above message and when I press "( " as displayed on the console,
I get the below command menu :
-----------MENU STARTS HERE---------------
[hostconsh] Command Menu:
1 --- Connect to Host subsystem console
2 --- Select Host subsystem boot mode: boot from local drive
3 --- Select Host subsystem boot mode: netboot manufacturing test
4 --- Select Host subsystem boot mode: netboot from external server
5 --- Reboot Host subsystem (sends reboot command)
6 --- Halt Host subsystem (sends halt command)
7 --- Reset Host subsystem (issues hardware reset--USE WITH CARE!)
8 --- Reboot SCCP subsystem (issues hardware reset--USE WITH CARE!)
9 --- Halt SCCP subsystem (issues hardware shutdown--USE WITH CARE!)
D --- Run Diagnostics
I --- Run BIG-IP Installer (issues hardware reset--USE WITH CARE!)
B --- SCCP baud rate configurator
L --- SCCP login
N --- SCCP network configurator
---------------MENU ENDS HERE------------------
But I don't know how to boot the BIG-IP from the above command menu.
have you ever had this kind of problem before ?
Please advise.
Thank you in advance.
Sakolan
  • How long did you wait after "Host Console Shell --- Press ( for command menu."?
    If you selec the sequence you enter the SCCP hardware layer. At this point you might as well select either 7 or 8.
    Otherwise reach for the phone and call F5 support.
  • hi,
    I send the BIG-IP to the support vendor. They said the boot files of the LB were damaged.
    So they have fixed the problem.
    It was not a harware problem. I think they just reset the BIG-IP..( I still don't know how they do that ..).
    So next time someone else gets the same problem, please send the BIG-IP to the maintenance contractor.it's safe and the fastest track.
    Anyway, thank you for ur reading.
    Sakolan.
  • you would think the install program would be smart enough and not allow you to downgrade. i'm running into the same problem 9.3.1 -> 9.2.3 and looking for solutions to unbricking my box. sending back to the vendor is not an option for me.
    edit: the only way i found to bring it back alive is to pxe server the install.
  • Deb_Allen_18's avatar
    Deb_Allen_18
    Historic F5 Account
    For future reference, the downgrading instructions are here:
    Click here
    To help clean up after not following them, here's a link to the SCCP netboot recovery / PXE installation instructions for 9.x: ">Click herehttps://support.f5.com/kb/en-us/solutions/public/4000/300/sol4312.html?sr=595677">Click here
    hth
    /deb
  • yoggit's avatar
    yoggit
    I followed the instructions and downgraded all 3 slots on my 3400 from 9.3.1 to 9.1.0 via a PXE server, but it still will not boot.
    I can PXE serve 9.3.1 nd get up and running, but I need to roll back to 9.1.0 and am stumped.
    Is there a way to blow away any partition tables and have the 9.1.0 PXE installation create them from scratch?
    -Jon
  • I think all you have to do is to do PXE installation and do a clean install to version 9.1.0.
    Check your PXE server is setup correctly.
    your 3400 doesn't boot correctly ? what error messages are displaying during the booting sequence ?
