Big IP javascript problem
Hi, Can somone can help me with problem on VS https for a web application doesn't work correctly This application use javascript When we are on the web site through the Big IP some value are missing With debug tool from IE we can see some problem on javascript execution: SCRIPT5007: Impossible d’obtenir la propriété « split » d’une référence null ou non définie SCRIPT5007: Impossible d’obtenir la propriété « getAttribute » d’une référence null ou non définie
Thank for help
David
- stan_piron
Cumulonimbus
Hi David,
Is The JavaScript sent from web server or added by the bigip?
Does it use external JavaScript hosted on an external http web site (not https)?
Browsers will prevent usage of http JavaScript if main web site is accessed on https URL.
Stanislas
