Big-IP APM v11.4.1 requires authentication again and again on IE11
Evironment detail is: Clients (Windows 7) > Big-IP APM v11.4.1 (Load balancer) > SharePoint Server 2013 (Windows Server 2012)
I have deployed a SharePoint app on SharePoint Server. Clients can access SharePoint app properly with Google Chrome but fail on IE11. Noted that AJAX calls are aborted. But IE11 works well when bypassed the load balancer (F5). I have observed that during navigating the app, Google Chrome does not require re-authentication with load balancer but IE11 requires and prompt Windows Authentication screen again and again.
As per our understanding could be possibility of following reasons: 1. Google Chrome intelligently persists authentication token at its end and present to F5 whereas IE11 does not. 2. F5 APM has a policy of re-authentication in multi/cross domain communication which IE11 follows. 3. Need to define static SPNs for domains. 4. F5 APM session holds authentication token but not send to SharePoint in case of IE11.
So let us know what could be the possible reason and how to handle it?
Regards, Jhan Zaib
- Lucas_Thompson_Historic F5 AccountI'd recommend gathering more supporting data before trying to jump to conclusions about what the cause is. Take some decrypted packet captures using ssldump on the Client <---> APM traffic and review the logs. Compare the behavior with Chrome and IE11. The difference between the two (both logging and client comms) should reveal the answer.
