DevendraJadhav's avatar
DevendraJadhav
Feb 12, 2024
BIG APM : Users facing slowness after connecting to BigIP Edge client.
Hello Team,
BIG APM : Users facing slowness after connecting to BigIP Edge client. When users are in home country they are not facing any slowness. When they are moving to other country suddenly facing slowness. Is it issue the with APM configuration?
  • Single-stream TCP throughput (like a user downloading a big file) will generally slow down as latency (ping time) increases. In situations such as web browsing where many TCP channels are opened simultaneously, the impact is usually less severe. I'd suggest trying:
    • Switch between DTLS and TLS modes to see if that makes a difference.
    • Since the VPN uses software encryption on the client side, make sure that your users CPU is not too high while they require high VPN throughput.
    • Make sure you have the latest Edge Client code. There have been many fixes over time that have greatly improved the speed.
    • Enable TLS Dynamic Record Sizing to improve congestion handling:  Dynamic Record Sizing
    Enabling Dynamic Record Sizing is a new recommendation that we've recently had some success with at some sites (sometimes 20%+ improvement) and would like to better understand how it behaves in more real world situations.
