Mandragor's avatar
Mandragor
Oct 15, 2020
BGP - Conditional announcement of directly connected networks
Is there any functionality to conditionally announce directly connected networks similarly to how you can use a route-map to conditionally announce a default route or how you can use RHI to conditionally announce kernel-routes?
My goal is to only announce connected routes on the active unit, but using
redistribute connected
announces the connected networks on all devices, while
redistribute connected route-map conditionalRoutemap
doesn't work (ie. the networks are not announced anywhere).
  • Hello Mandragor.
    Try to configure it with "in/out" parameter.
    You can also try with neighbor field instead.
    REF - https://support.f5.com/csp/article/K10095057
    Regards,
    Dario.
    • Mandragor's avatar
      Mandragor
      Thank you for your suggestion, but my issue is not to filter which connected networks to announce but on which device - I want to ensure that the connected networks are only announced on the active device, and by using neighbor route-map or prefix-list I still announce any matched network on the standby device as well, unfortunately.
      • Dario_Garrido's avatar
        Dario_Garrido
        Icon for Noctilucent rankNoctilucent
        Hello Mandragor.
        Your syntax should be fine.
        redistribute [connected|isis|kernel|ospf|rip|static] route-map WORD
        The issue could be in how your "conditionalRoutemap" is configured.
        Could you share it?
        Regards,
        Dario.
