jbackman's avatar
jbackman
Nov 19, 2018
Bandwidth limiting and reporting per client
I am trying to implement bandwidth limiting and reporting on a per client basis, but am not sure it is working they way I intend. I want to limit each client to 150 Mbps using bandwidth control and then be able to report when a client is actually being rate limited. I created my BWC config with the following config:
create net bwc policy BC-BCS-RLPC {max-rate 160gbps max-user-rate 150mbps dynamic enabled}
The original script we used was:
when RULE_INIT {
     Bandwidth in bytes/sec
    set static::maxBandwidth 18750000
    set static::logDelay 300
when CLIENT_ACCEPTED {
    set hsl [HSL::open -publisher /Common/management-port-pub]
    set srcip [IP::client_addr]
    BWC::policy attach BC-BCS-RLPC $srcip
    HSL::send $hsl  "<158> User $srcip attached to BC-BCS-RLPC"
    if {[ set logLastTime [table lookup -subtable lastBandwithLog $srcip ]] eq "" } then {
        set bw [TCP::bandwidth]
        if { $bw > $static::maxBandwidth } {
            table add -subtable lastBandwithLog $srcip 1 indef $static::logDelay
            HSL::send $hsl  "<158> User $srcip bandwidth $bw exceeds the BWC limit of $static::maxBandwidth"
But this seems to display a strange maximum value of 16776960 (possibly a limit on the TCP::bandwidth reporting)
I have rewritten the script as:
when RULE_INIT {
     Bandwidth in bits/sec
    set static::maxBandwidth 150000000
        set totalTime [ expr  { [IP::stats age] / 1000 } ]
        set bpsOut [ expr { ( [IP::stats bytes out] * 8 ) / $totalTime } ]
        set bpsIn  [ expr { ( [IP::stats bytes in] * 8 ) / $totalTime } ]
        if { $static::maxBandwidth < $bpsIn || $static::maxBandwidth < $bpsOut } {
            HSL::send $hsl  "<158> User $srcip bandwidth $bpsIn/$bpsOut (in/out) exceeds the BWC limit of $static::maxBandwidth"
  1. Does the new script do what I intend it to do (attach a client IP to a specific BW policy and report on a sliding 5 minute window when the client exceeds the limit)
  2. Are there any performance concerns with the new script
  3. Is there a better way to do this?
