JoshBarrow's avatar
May 14, 2020
Automation with iControl to upload SSL Cert & Key
I'm trying to create a script via powershell to automate and upload .crt and .key files to our BIG IP environment. I know there are ways to do it via powershell, Just need a place to start. Please help.
  • Found out what I could use. It is actually pretty helpful for folks using Powershell to leverage REST. Thanks to some old buddies of mine. Hopefully this can help someone else as well.
    $bigip = Read-Host "BigIP Name: " #Name you would put inside the Web Browser
     #Calculate content-range
    $standalonefile = Read-Host "Full Filename Inside: "
    $pathtofile = "path for the file" + $standalonefile
    $file = [IO.File]::ReadAllBytes($pathtofile)
    $enc = [System.Text.Encoding]::GetEncoding("iso-8859-1")
    $encodedfile = $enc.GetString($file)
    $range = "0-" + ($encodedfile.Length - 1) + "/" + $encodedfile.Length
    $headers = @{ "Content-Range" = $range}
     #Upload the file
    $filename = Read-Host "Enter Name for inside the BigIP Temp Folder: " #This will be the name of the file inside the bigIP Temp Folder
    $url = "https://" + $bigip + "/mgmt/shared/file-transfer/uploads/" + $filename
    $credentials = Get-Credential
    pause
    $uploadresult = Invoke-WebRequest $url -Credential $credentials -method Post -Headers $headers -InFile $pathtofile -ContentType "multipart/form-data" -TimeoutSec 20 | ConvertFrom-Json
     #Add new certificate
    class cert
      [string]$command
      [string]$name
      [string]$fromLocalFile
    $cert = New-Object -TypeName cert
    $cert.command = "install"
    $cert.name = Read-Host "Enter Name for inside the BigIP Cert Store:" #this is what will show up inside the cert store. in the F5
    $cert.fromLocalFile = $uploadresult.localFilePath
    $body = $cert | ConvertTo-Json
    $url = "https://" + $bigip + "/mgmt/tm/sys/crypto/cert"
    $certresult = Invoke-WebRequest $url -Credential $credentials -method Post -Body $body -ContentType "application/json" -Headers $headers2 | ConvertFrom-Json
