dwhite12_255934's avatar
dwhite12_255934
Jan 05, 2017
Solved
Assistance with iRule for substitue/redirect - LTM
Web developer would like this behavior:
so if a GET request is made to 'testsite2.com/unsubscribe.php[?params&params]' it should be forwarded to https://testsite2.com/testapp/unsubs/unsubscribe.php[?params&params]
Tried this with a variation of a previous DevCentral response:
when HTTP_REQUEST { if { ([HTTP::host] eq "testsite2.com") and ([string tolower [HTTP::uri]] ends_with "/unsubscribe.php") } { HTTP::respond 308 Location "; } }
Seems to be resulting in a 404 when parameters are supplied stating: /unsuscribe.php (The requested resource is not available)
Thanks in advance,
Doug
  • Hi,
    what will happen if you directly went to this?
     http://testsite2.com/testapp/unsubs/unsubscribe.php
    try this:
        if { [HTTP::host] equals "testsite2.com" && [HTTP::uri] starts_with "/unsubscribe.php" } {
            HTTP::respond 301 noserver Location "/testapp/unsubs/unsubscribe.php"
    OR
            HTTP::redirect "http://testsite2.com/testapp/unsubs/unsubscribe.php"
    SELECTED ANSWER - This will keep your parameters and will only replace the url:
            set uri [string map {"/unsubscribe.php" "/testapp/unsubs/unsubscribe.php"} [HTTP::uri]]
            HTTP::redirect "http://[HTTP::host]$uri"
  • Hi,
    try this:
    OR
