Nuruddin_Ahmed_'s avatar
Nuruddin_Ahmed_
Mar 09, 2016
Application not working with only IE - res://ieframe.dll/dnserror.htm
I hosted two applications recently on F5 and they are pretty straightforward IIS based web applications. These applications are working from all browsers except from IE. The error we get is "res://ieframe.dll/dnserror.htm"
Any idea on that?
Regards
  • Hi,
    This issue may be indicating many issues. Maybe you should try on another PC with the same version of IE. Sometimes, the Internet settings block the content from displaying within your browser. Right click on the app and select properties. Find the Zone your app belong to and then check options of the corresponding zone in the Security tab within Internet settings
