application blocked http compliance failed (Body in GET or HEAD requests)
Hi
We are using F5 os ver 12.1.2 with ASM module.
and we are getting blocked some business application pages under http compliance failed (Body in GET or HEAD requests) not able to dig down the exact root cause.
dont know how to handle this. we are not able to disable the properties of Body in GET or HEAD requests. because our customer is not allowing the same.
Please help on priority.
- nathe
Cirrocumulus
Lenv33, the only option then is to remove the blocking setting against this violation in the policy settings section of the GUI.
Hope this helps,
N
- Vijay_E
Cirrus
If this is emergency, you are better off opening up a case as this requires a lot of data from the device in order to understand the existing policies and what is being blocked. Did you get to check the logs to get some hint on possible reasons for blocking ?
- lenv33_310445
Hi All,
any one is there who can help me with this. not able to justify why this is blocking the request
- Torti
Cirrus
still exists at asm 12.1.3
- Martin_326665
I have the same issue after upgrade from v11. It is caused by client sending GET request with HTTP header "Content-Type".
- MSZ
Please refer the following page:
https://devcentral.f5.com/questions/enabling-http-check-for-specific-uri-59340
