Justin_106620's avatar
Justin_106620
May 08, 2017
append irule based on source address help
I am in need of an irule to append a uri if your source address is not x.x.x.x The /auth-smartweb redirects you to our adfs for single signon. once authenticated your are brought back to the site. The below irule works in a sense as it appends the /auth-smartweb but once you authenticate you get in a loop and the site never loads.
when HTTP_REQUEST { if { not ( [IP::addr [IP::client_addr] equals a.b.c.c/16] ) } { HTTP::uri /auth-smartweb } }
if I use a simple append without looking at the source address everything works fine and you don't get in this loop.
when HTTP_REQUEST { if {([HTTP::uri] == "/") } { HTTP::uri /auth-smartweb } }
Am I doing anything wrong? is there a better way to do this?
  • Seems to me that you need to test for both the IP address being in the specified range as well as the URI being equal to "/".
  • Hi,
    Try this code
        if { not ( [IP::addr [IP::client_addr]/16 equals a.b.0.0] ) } {
