njseq's avatar
njseq
Jul 25, 2019
APM Machine Cert Auth Macro Issues
Hello,
I have several VS each one with an Access Profile.
On one critical Access Profile I have a macro Machine Cert Auth to inspect client's machine to check if there's a user and machine certificate.
I also need the user to access the APM through Internet Explorer browser because we will use Windows Cache and Session Control macro. which requires IE.
The APM logon page uses Swivel turing image and it does not work because of the Machine Cert Auth inspector. Even if I click CANCEL and SKIP to install the inspector.
If I remove the macro then it works. It will show the Swivel turing image.
I've seen this NOT happening with other browsers on other client machines but it is not 100% true because I've also seen differently. Example, if I use Chrome, it works with Machine Cert Auth macro.
So do you guys know what can this be ?
Any clue or workaround this?
Thanks.
Kind regards,
NS
