APM Logging and mobile devices
Hi, I have a network access VPN setup in my LTM/APM. The access policy is setup for windows users and mobile users. The windows users must have a specific reg entry and proper AD creds to connect. The mobile users must have a certificate in order to connect. Looking at the Access Policy> reports, under the column “Logon”, only my windows users UID shows, my mobile users are showing as blank.
APM Log:
Looking at my access policy: My mobile users really only have to pass the certificate test and they’re in.. My question, since my mobile users are not going through the actual logon page, would that be the reason for the UID not showing up in the access policy report?
Thanks, Danny
- kunjan
If you extract the username from the cert and do a 'Variable Assign' to session.logon.last.username in the VPE, I think you will see the field populated.
- DannyG_34437
Cirrus
Thanks.. I'll look into this approach... dg
- kunjan_118660
Cumulonimbus
- DannyG_34437
Cirrus
