APM EWS Remote Connectivity Analyser
Hello
Found strange issue with APM protecting Exchange 2019
Deployed configuration using Appendix C: Manual configuration tables from https://www.f5.com/pdf/deployment-guides/microsoft-exchange-2016-dg.pdf
Everything working fine (all required protocols). But Microsoft Remote Connectivity Analyser https://testconnectivity.microsoft.com/tests/EwsAccess/input shows that Autodiscovery and EWS cannot be reached (timeout error)
I took decrypted tcpdump for traffic from Remote Connectivity Analyser (RCA) and found that front-end request (RCA-F5) contains Basic Authorization header, but back-end request (F5-Exchange) does not contain one
Front-End request
POST /EWS/Exchange.asmx HTTP/1.1
Content-Type: text/xml; charset=utf-8
Accept: text/xml
User-Agent: ExchangeServicesClient/15.20.7828.000
Accept-Encoding: gzip,deflate
X-RCA-IgnoreCertificateTrust: true
X-ClientStatistics: MessageId=,ResponseTime=99882,SoapAction=GetFolder;
Authorization: Basic BASE64_STRING
Host: exchange.domain.tld
Content-Length: 764
Expect: 100-continue
X-Forwarded-For: 52.109.8.10
Back-End request
Header "Authorization: Basic BASE64_HIDDEN_STRING" is missing
Header "APM_session: a63a0c88" is added by standard iRule from Exchange deployment guide
Accept: text/xml
Content-Length: 764
HTTP/1.1 401 Unauthorized
Server: Microsoft-IIS/10.0
request-id: b9c88db3-461b-427b-9be0-54915949a9e5
X-OWA-Version: 15.2.1544.11
WWW-Authenticate: Negotiate
WWW-Authenticate: NTLM
X-Powered-By: ASP.NET
X-FEServer: EXCHANGE_SERVER
Date: Fri, 09 Aug 2024 18:38:16 GMT
Content-Length: 0
Logs from APM:
Policy result allow, so everything should be fine
VPE with name "App EXCH" contains SSO credential mapping
# grep a63a0c88 /var/log/apm
2024-08-09T21:33:43.488+03:00 bigip01 notice apmd[7113]: 01490115:5: /PARTITION/Exchange_access:PARTITION:a63a0c88: Following rule 'Client for MS Exchange' from item 'Client for MS Exchange' to terminalout 'Client'
2024-08-09T21:33:43.488+03:00 bigip01 notice apmd[7113]: 01490010:5: /PARTITION/Exchange_access:PARTITION:a63a0c88: Username 'domain\test_user'
2024-08-09T21:33:43.507+03:00 bigip01 notice apmd[7113]: 01490115:5: /PARTITION/Exchange_access:PARTITION:a63a0c88: Following rule 'Successful' from item 'AD Auth' to terminalout 'Success'
2024-08-09T21:33:43.516+03:00 bigip01 notice apmd[7113]: 01490115:5: /PARTITION/Exchange_access:PARTITION:a63a0c88: Following rule 'memberOf' from item 'AD Query' to terminalout 'Success'
2024-08-09T21:33:43.517+03:00 bigip01 notice apmd[7113]: 01490009:5: /PARTITION/Exchange_access:PARTITION:a63a0c88: ACL '/PARTITION/Exchange_acl' assigned
2024-08-09T21:33:43.517+03:00 bigip01 notice apmd[7113]: 01490115:5: /PARTITION/Exchange_access:PARTITION:a63a0c88: Following rule 'fallback' from item 'Advanced Resource Assign' to terminalout 'Out'
2024-08-09T21:33:43.517+03:00 bigip01 notice apmd[7113]: 01490005:5: /PARTITION/Exchange_access:PARTITION:a63a0c88: Following rule 'Out' from item 'App EXCH' to ending 'Allow'
2024-08-09T21:33:43.518+03:00 bigip01 notice apmd[7113]: 01490102:5: /PARTITION/Exchange_access:PARTITION:a63a0c88: Access policy result: LTM+APM_Mode
2024-08-09T21:33:43.519+03:00 bigip01 notice apmd[7113]: 01490248:5: /PARTITION/Exchange_access:PARTITION:a63a0c88: Received client info - Hostname: Type: unknown Version: 0 Platform: unknown CPU: unknown UI Mode: Full Javascript Support: 0 ActiveX Support: 0 Plugin Support: 0
APM config:
Exchange profile according to latest docs. Front-end authorization is Basic and back-end is NTLM. As described on page 113 on deployment guide
apm profile access /PARTITION/Exchange_access {
exchange-profile /PARTITION/Exchange_exchange
apm profile exchange /PARTITION/Exchange_exchange {
app-service none
auto-discover-auth-type basic
auto-discover-sso-config /PARTITION/Exchange_ntlmv2
ntlm-auth-name none
offline-address-book-auth-type basic
offline-address-book-sso-config /PARTITION/Exchange_ntlmv2
rpc-over-http-auth-type basic
rpc-over-http-sso-config none
web-service-auth-type basic
web-service-sso-config /PARTITION/Exchange_ntlmv2
web-service-url /[ae][pw][is]/*
apm sso ntlmv2 /PARTITION/Exchange_ntlmv2 {
ntlm-domain corp.domain.tld
partition PARTITION
However we do not have BIG-IP NTLM account created in Active Directory. Deployment guide does not instruct to force this action
I tried to switch "auto-discover-sso-config", "offline-address-book-sso-config" and "web-service-sso-config" to "none" instead of ntlmv2 object but issue is still there
Have anybody such issues with APM protected Exchange? Could you please check and share with me your Exchange profile if your EWS test will succeed?
Thanks!
Depenging on how username is provided in login page, session.logon.last.domain variable might not be setted.
session.logon.last.domain is used be default on NTLM sso config.
As you have AD Auth on the VPE, I would suggest changing the sso configuration to use session.ad.last.actualdomain as the domain source and try again.
Unfortunately that did not helped me :(
I tried both options:
- Use session variable "session.ad.last.actualdomain" for NTLMv2 SSO object. That value exactly matches "ntlm-domain" under apm sso ntlmv2 /PARTITION/Exchange_ntlmv2
- Use session.logon.last.domain and set "ntlm-domain" to DOMAIN (NetBIOS domain name) under apm sso ntlmv2 /PARTITION/Exchange_ntlmv2
Seems that something else stops APM from attaching SSO to the back-end request
Moreover all my tests shows now that APM did not send any request to the /EWS/Exchange.asmx even after I reverted all the changes back. BIG-IP reboot did not helped :)
Are you using the same sso for the other services?
Does it work there?
Nope, the only service is Exchange for this SSO object
If you have APM policy for Exchange may I ask you to check EWS health on Microsoft Remote Connectivity Analyser?
I mean other Exchange services except EWS, like OWA for example.
