Ryan_34424's avatar
Ryan_34424
9 years ago
APM :: Remote Desktop List :: Remote Sound Not Working
Has anybody ran into where the remote audio is not being played locally?
I have the local sound box checked, and I even tried the audiomode:i:0 custom parameter (even though it's defaulted to zero), and neither seem to be working. I know it's nothing wrong with the workstation (or so it seems) because the other VPN solution that I'm trying to migrate off of works perfectly fine.
General Properties:
Local Resources:
I haven't been able to get monitor spanning to work either (no matter what combination of anything I use)... but that's a whole other issue.
Thanks-
  • Hi Ryan I met the same problem with version 13 and native RDP Client, connection is ok, everything goes fine except that the audio peripheral is not present in the session. Audio parameters have been parametred in the mstsc client. Any idea ? Thanks
  • Upgrading to version 13 and using the native RDP client resolved the audio issue.
