Stefano_it_2554's avatar
Stefano_it_2554
Feb 08, 2017
APM - Keep alive a session given a sid
Hi, I'm writing a iRule for keep alive the session with sid read from http header.
How can I refresh the session ttl with inactivity timeout value of access profile?
    set sidToRefresh [HTTP::header value sid]
    log local0. "sid To Refresh:$sidToRefresh"
    if { [ACCESS::session exists -sid $sidToRefresh] } {
         keep alive the session "sidToRefresh"
Can anyone help me? Thanks
  • Hi Stefano,
    unfortunately you can't reset the inactivity timeout for a given user session via the various [ACCESS::*] commands. You have to pass the APM filter using a valid MRHSession=SID cookie to reset the inactivity timer.
    Depending on your detailed usecase, you could try to impersonate the ongoing HTTP request containing the provided [HTTP::header value sid] value and then request either a 1x1.gif on the backend systems or even a specific code block within the ACCESS_ACL_ALLOWED event. Check out the iRule below to get some ideas...
        if { $sidToRefresh ne "" } then {
            if { [ACCESS::session exists -state_allow -sid $sidToRefresh] } then {
                HTTP::cookie remove MRHSession
                HTTP::cookie insert name MRHSession value $sidToRefresh
                set reset_timeout 1
                HTTP::respond 200 content "The requested SID \"$sidToRefresh\" does not exists or is already inactive"
             The request does not contain a SID header.
    when ACCESS_ACL_ALLOWED {
        if { [info exists reset_timeout] } then {
            ACCESS::respond 200 content "Successfully reset the timeout timer for SID \"$sidToRefresh\""
            unset -nocomplain reset_timeout
    Note: If the solution above doesn't fit into your usecase, then please explain a little bit more what you're trying to accomplish.
    Cheers, Kai
