sean2015's avatar
sean2015
Mar 13, 2019
Ansible can not connect to LTM
Ansible 2.7.8 LTM 11.6.3.3
Our ansible can not connect to LTM 11.6.3,but can cconnet to 11.2.2. error like below with ltm 11.6.3.
[root@ansible ansible] ansible lc_2000s -m ping 192.168.10.51 | FAILED! => { "changed": false, "module_stderr": "Shared connection to 192.168.10.51 closed.\r\n", "module_stdout": " File \"/root/.ansible/tmp/ansible-tmp-1552535729.71-249816294231104/AnsiballZ_ping.py\", line 39\r\n with open(module, 'wb') as f:\r\n ^\r\nSyntaxError: invalid syntax\r\n", "msg": "MODULE FAILURE\nSee stdout/stderr for the exact error", "rc": 1 } 192.168.10.52 | FAILED! => { "changed": false, "module_stderr": "Shared connection to 192.168.10.52 closed.\r\n", "module_stdout": " File \"/root/.ansible/tmp/ansible-tmp-1552535729.71-227266259443091/AnsiballZ_ping.py\", line 39\r\n with open(module, 'wb') as f:\r\n ^\r\nSyntaxError: invalid syntax\r\n", "msg": "MODULE FAILURE\nSee stdout/stderr for the exact error", "rc": 1 } [root@ansible ansible]
