GavinW_29074's avatar
GavinW_29074
Feb 17, 2012
Another ProxyPass issue :(
Me again...
I've hit another issue with the ProxyPassv10 iRule...
Currently, we've got several VIP's set-up using the ProxyPass irule.
One of these VIPs is set-up as follows:
list /ltm virtual TfGM_CMS.app/service.card.co.uk_https
ltm virtual TfGM_CMS.app/service.card.co.uk_https {
app-service /Common/TfGM_CMS.app/TfGM_CMS
destination 172.16.26.11:https
ip-protocol tcp
mask 255.255.255.255
pool TfGM_CMS.app/TfGM_CMS_pool
profiles {
HTTP_Rewrite { }
TfGM_CMS.app/cmsws_gmpte_card_co_uk_ssl {
context clientside
oneconnect { }
stream { }
tcp-wan-optimized { }
wan-optimized-compression { }
rules {
ProxyPass
SplunkHTTP
CatchErrors
HeaderStripping
MaintenancePage
HandleErrors
ClientSSLVerification
snat automap
vlans-disabled
The data-group used by the ProxyPass rule on this VIP contains:
list /ltm data-group internal ProxyPass_cmsws
ltm data-group internal ProxyPass_cmsws {
records {
/CMSBureauWebService/CMSBureauWS {
data /CMSBureauWebService/CardBureauService
/CMSBureauWebService/CardBureauService {
/CMSWebPortalService/CardRenewalWebPortal_2_0 {
data /CMSWebPortalService/CardRenewalWebPortal_2_0
/CMSWebPortalService/VoucherRedemptionService {
data /CMSWebPortalService/VoucherRedemptionService
/CMSWebPortalService/WebPortalService {
data /CMSWebPortalService/WebPortalService
type string
RewriteResponsePayload is set to a value of 2, and the VIP has a Stream profile attached.
However I'm still seeing the following errors logged on making requests:
Feb 17 15:50:04 tmm3 info tmm3[9382]: Rule /Common/ProxyPass : VS=/Common/TfGM_CMS.app/service.card.co.uk_https, Host=service.card.co.uk, URI=/CMSBureauWebService/CMSBureauWS: Error setting stream expression (). If you enable static::RewriteResponsePayload, then you should add a stream profile to the VIP. Else, set static::RewriteResponsePayload to 0 in this iRule.
If I enable verbose logging, I get:
Feb 17 15:50:04 tmm3 info tmm3[9382]: Rule /Common/ProxyPass : Processing HTTP_RESPONSE at Priority 900.
Feb 17 15:50:04 tmm3 info tmm3[9382]: Rule /Common/ProxyPass : VS=/Common/TfGM_CMS.app/service.card.co.uk_https, Host=service.card.co.uk, URI=/CMSBureauWebService/CMSBureauWS: $stream_expression_cmd: STREAM::expression "@https?://service.card.co.uk/CMSBureauWebService/CardBureauService@https://service.card.co.uk/CMSBureauWebService/CMSBureauWS@ @https?%3A%2F%2Fservice.card.co.uk%2FCMSBureauWebService%2FCardBureauService@https%3a%2f%2fservice.card.co.uk%2fCMSBureauWebService%2fCMSBureauWS@ @/CMSBureauWebService/CardBureauService@/CMSBureauWebService/CMSBureauWS@ @%2FCMSBureauWebService%2FCardBureauService@%2fCMSBureauWebService%2fCMSBureauWS@", $stream_enable_cmd: STREAM::enable
I cant see any issues with the STREAM::expression value of the STREAM::cmd...
Any ideas what could be causing the above error?
Regards
Gavin
  • hoolio's avatar
    hoolio
    Hi Gavin,
    Are you customizing the STREAM::expression somewhere? I was able to set the stream expression to yours on a test virtual server and it worked:
    when HTTP_RESPONSE {
    STREAM::enable
    Aaron
  • Aaron
    Nope, the ProxyPass rule is the only rule that uses STREAM expressions...
    However I've noticed today that the log errors have stopped, with no other changes being made... So not sure what happened there, but it looks like it's resolved itself :s
    Gav
