After going through the guide for F5 on AWS, I cannot ping the Elastic IP
I have gone through the document a couple of times, and when I hit "Connect" and then type in the ssh -i "aws_f5_march.pem" [email protected] or root@ -- it times out.
Ping 52.73.38.5 also times out.
- Seth_81884Historic F5 Account
Hello TTF888,
Assuming the BIG-IP has successfully reported '2/2 checks passed', this sounds like a security group configuration issue. The example given in 'Creating New Security Groups' section of the guide below is wide open, so it should be refined for your environment.
Can you ping any other guests that are using the same VPC?
The AMI-ID of the BIG-IP you are deploying and the AWS region may be helpful in troubleshooting.
- TTF888_160708
I am only trying to ping public IP addresses and that doesn't appear to work. I checked my security groups. I have it set to All Traffic inbound and outbound 0.0.0.0/24 - TTF888_160708
https://www.dropbox.com/s/xnohd8bf76i0bd5/Screenshot%202016-03-16%2020.55.54.png?dl=0 - TTF888_160708
F5 Networks Hourly Hotfix-BIGIP-11.6.0.4.0.420-HF4 - Good 25Mbps - built on -fa8a82ce-7679-467d-9880-16497f3ac022-ami-f04b6d98.2 (ami-e08ea588)
