AFM: Matching order between AFM rule and NAT
I have a question on AFM and matching order process between AFM Fw rule and LTM NAT.
When I create a new rule, which IP should I use ? Origin or translated IP ?
Best regards
- Thomas_Gobet
Which NAT are you talking about ? If it's SNAT applied on a VS, you don't need to know it when you're on AFM.
SNAT is applied when the packet is leaving out your BIG-IP.
- brahim94_11525
Thank you for the feedback,
OK so for the SNAT when I create rule, I have to use the origin IP. Is it the same thing for destination NAT (create via LTM -> NAT List + Create) ?
Best regards,
- Thomas_Gobet
It's the same for the NAT List, you have to use the "original" destination IP.
But be careful, it will be under Global level. - brahim94_11525
OK, we are agree.
Thanks a lot
