gnomemade_16346's avatar
gnomemade_16346
Mar 17, 2015
Adding spaces between semicolon seperated cookie elements
I'm using the following irule to add secure/httpOnly attributes to cookies:
when HTTP_RESPONSE {
foreach aCookie [HTTP::cookie names] {
        set ck_value [HTTP::cookie value $aCookie]
        set ck_path [HTTP::cookie path $aCookie]
        HTTP::cookie remove $aCookie
        HTTP::cookie insert name $aCookie value $ck_value path $ck_path version 1
        HTTP::cookie httponly $aCookie enable
        HTTP::cookie secure $aCookie enable
It's doing what I want but the resulting cookie looks like this with no spaces after the semicolons:
Set-Cookie:.ASPXAUTH=xxxxxxxxxxxxxxxxxxx;Secure;HttpOnly;Path=/;Version=1;
Everything is working as it should but not having a space after the semicolons makes it a little harder to read and I can't seem to find any info if no spaces is acceptable from a standards perspective.
Can anyone tell me if having no spaces is ok from a standards / compatibility standpoint and if there is an easy way to add a space after each semicolon?
  • Hi,
    Based on RFC6265 http://tools.ietf.org/html/rfc6265section-5.2 Section 5.2, Step 5 then RFC says to strip the white space characters. Having no spaces should be find from a standards point of view.
    The user agent MUST use an algorithm equivalent to the following
       algorithm to parse the unparsed-attributes:
       1.  If the unparsed-attributes string is empty, skip the rest of
           these steps.
       2.  Discard the first character of the unparsed-attributes (which
           will be a %x3B (";") character).
       3.  If the remaining unparsed-attributes contains a %x3B (";")
           character:
         Consume the characters of the unparsed-attributes up to, but
              not including, the first %x3B (";") character.
           Otherwise:
           Consume the remainder of the unparsed-attributes.
           Let the cookie-av string be the characters consumed in this step.
       4.  If the cookie-av string contains a %x3D ("=") character:
           The (possibly empty) attribute-name string consists of the
              characters up to, but not including, the first %x3D ("=")
              character, and the (possibly empty) attribute-value string
              consists of the characters after the first %x3D ("=")
              character.
           Otherwise:
           The attribute-name string consists of the entire cookie-av
              string, and the attribute-value string is empty.
       5.  Remove any leading or trailing WSP characters from the attribute-
           name string and the attribute-value string.
       6.  Process the attribute-name and attribute-value according to the
           requirements in the following subsections.  (Notice that
           attributes with unrecognized attribute-names are ignored.)
       7.  Return to Step 1 of this algorithm.
    -Seth
