Active and Passive not Sync automatically
Dear All
I am new in F5 Big-IP. Couple of days i am facing a problem that my two F5 Big-IP configuration is not syncing automatically. with the help of the following community support post i syn the two Big-IP
https://devcentral.f5.com/questions/active-passive-waf-behave-differently-53448
But now i don't find any option to syn the two system. The state is as like follows:
What can i do now. and why this happen.
Please help.
- Rockers_319329
Anybody can help? Need help?
- BB16
Hi Rockers,
You can go to below link of F5 support & search with key word "SYNC" will possibly show your solution.
- There is sample confg-sync sample configuration.
- Manual & Auto config config.
- config sync IP
- Creating steps for config-sync config.
- Simon_Blakely
Employee
Go to
Device Management ›› Overview
Select your Device Group Failover_group
Select the most current device and hit the Sync button
