zak_thompson_86
May 12, 2007404 reselect help
so i'm trying to create somthing that will try every pool member for a response and once it goes through every active member and they are all 404's to default to a pool that will always have the content. this is needed to help serve content while the servers are syncing with each other.
when CLIENT_ACCEPTED {
set retries 0
set request [HTTP::request]
when LB_SELECTED {
if {$retries >= [active_members ddf-big-media01] } {
LB::reselect pool ddf-backend
log local0. "RETRY!"
when HTTP_RESPONSE {
if { [LB::server pool] equals "ddf-big-media01" } {
if { [LB::server pool] != "ddf-backend" } {
if { [HTTP::status] eq "404" } {
incr retries
log local0. "REtrying pool"
HTTP::retry $request
}I see in examples people say to use the LB::reselect syntax inside http_response however.. the appliance screams at me everytime i try and wont let me do it. there a way around this??
- Colin_Walker_12Historic F5 AccountThere was some confusion initially around the LB::reselect command and where it was applicable. It looks like you're implementing it in the intended fashion, as it's not usable under the response event.
Is your rule working?
Colin - zak_thompson_86
no its not working, it would flip to the other pool right away it never tried the other nodes.
