Karthick1's avatar
Karthick1
Icon for Cirrus rankCirrus
Nov 13, 2025
F5 XC HTTP 404 rout_not_found / rsp_code 404
I would like to add more point about the HTTP 404 error: route_not_found / rsp_code 404 in an XC (RE + CE) deployment.
1. Even if XC has the correct host match value in the route, you might still observe a 404 response. In such cases, check the DNS configuration on the CEs.
                A possible reason could be that the CEs are unable to resolve DNS for host which is configured in route.
2. Even if XC has the correct host match value, the path might not match. For example, if you have a single route as shown below and the request comes as https://example.com/, you may see rsp_code 404 , as it is not matching any routes.
Example :
HTTP Method:ANY
Path Match : Prefix
Prefix:/hello
Headers
Host  example.com
Orginpool: example_orgin pool
https://my.f5.com/manage/s/article/K000147490
  • Below are the response
    Request & Response
    req_id
    XXXXXXXXXXXXXXXXXXX0
    method GET
    host example.com
    req_path/
    req_body -
    api_endpoint :UNKNOWN
    scheme :https
    rsp_code :404
    rsp_code_details :route_not_found
  • The XC CE does not resolve the host in the route match. Maybe you mean can't resolve the pool's origin server that route uses. If the pool under the route is FQDN and the CE or RE can't resolve it then you can get similar error or "cluster_not_found" in the logs.
    For the second point yes this is why have a default pool under the HTTP LB or default route at the end with Prefix:/
    Also for HTTPS you may get RST (I think on the RE) in some cases and the logs will show the clear error.
  • There are a couple of cases when XC can return 404:
    1. A route contains multiple pools and all clusters/pools are down (health check)  - XC returns 404 instead of 503
    2. In case the advertise policy is the CE itself, the VIP will be retracted
    • Nikoolayy1's avatar
      Nikoolayy1
      Icon for MVP rankMVP
      We have an F5 XC expert on board that I had the pleasure to work with.
