walt_97468
Dec 02, 2008302 redirect string capture and replace
I have modified a previous post for this irule:
HTTP::header replace "Host" "www.test.com"
when HTTP_RESPONSE {
HTTP::header replace "Host" "www.test2.com"
if { [HTTP::status] starts_with "3"} {
if { [HTTP::header location] contains "http://www.redirect.com/" } {
set newLoc [string map {www.redirect.com www.test2.com} [HTTP::header location] ]
HTTP::header replace location "$newLoc"
We are replacing the host for both requests and responses. Also,when a server sends a 302 response (and I also want to look for 301's), the response includes a location field. A packet capture shows that the loaction field is set to "http://www.redirect.com"
All I need to do is to change www.redirect.com to www.test2.com, and leave the rest of the URI intact. Am I going about this the right way?
Thanks for your help!
