luoye's avatar
luoye
Apr 16, 2017
12.1.1 ve modify setting error
Hi,guys: When I modify setting in the web GUI,there are err log "Apr 14 16:18:43 big-ip-1 warning mcpd[6504]: 01071031:4: Security setting systemauth.disablerootlogin has been disabled by user admin Apr 14 16:18:43 big-ip-1 err mcpd[6504]: 01070912:3: unable to open file: /tmp/confpp.dat Apr 14 16:18:43 big-ip-1 err mcpd[6504]: 01070712:3: Caught configuration exception (0), unable to open file: /tmp/confpp.dat. Apr 14 16:18:44 big-ip-1 err tmsh[6310]: 01420006:3: Can't create temp directory, /.config.tmp/yQpX5k, errno 30] Read-only file system"
What's more,I input "tmsh" in the CLI,there is a err log"big-ip-1 crit tmsh[6448]: 01420001:2: Can't open command history file (/root/.tmsh-history-root), Read-only file system : framework/CmdHistoryFile.cpp, line 92" Do you have seen this situation?I can't find anything in the askF5.The systmem is 12.1.1 VE.
  • It seems one or more partitions are mounted 'read-only' on your BIG-IP. You can check this by running the command 'mount' from bash. Could you show us the output of this command?
    Also the output of 'ls -la /' would be interesting, to see how the permissions on the /tmp and /root directory are set.
  • luoye's avatar
    luoye
    Hi,friend.How can I find the problem?
    [root@big-ip-1:ModuleNotLicensed:Active:Standalone] config mount
    /dev/mapper/vg--db--sda-set.1.root on / type ext3 (rw,noatime)
    none on /proc type proc (rw)
    devpts on /dev/pts type devpts (rw) none on /dev/shm type tmpfs (rw,noatime,rootcontext="system_u:object_r:tmpfs_t:s0")
    /dev/mapper/vg--db--sda-set.1._config on /config type ext3 (rw,noatime)
    /dev/mapper/vg--db--sda-set.1._usr on /usr type ext3 (ro,noatime)
    /dev/mapper/vg--db--sda-set.1._var on /var type ext3 (rw,noexec,noatime)
    /dev/mapper/vg--db--sda-dat.share.1 on /shared type ext3 (rw,noatime)
    /dev/mapper/vg--db--sda-dat.log.1 on /var/log type ext3 (rw,noatime) none on /shared/rrd.1.2 type tmpfs (rw,noatime,rootcontext="system_u:object_r:file_t:s0") none on /var/tmstat type tmpfs (rw,rootcontext="system_u:object_r:file_t:s0") none on /var/run type tmpfs (rw,noatime,rootcontext="system_u:object_r:file_t:s0") none on /sys/kernel/debug type debugfs (ro,noexec) prompt on /var/prompt type tmpfs (rw,size=4m,rootcontext="system_u:object_r:file_t:s0") none on /proc/sys/fs/binfmt_misc type binfmt_misc (rw) none on /var/loipc type tmpfs (rw,noatime,rootcontext="system_u:object_r:var_t:s0") /var/named/lib on /var/named/lib type none (rw,bind) /dev/mapper/vg--db--sda-app.ASWADB.set.1.mysqldb on /var/lib/mysql type ext3 (rw,noatime) /dev/mapper/vg--db--sda-app.avr.dat.avrdata on /shared/avr type ext3 (rw) none on /dev/mprov/avr type hugetlbfs (rw) none on /dev/mprov/tmm type hugetlbfs (rw)
    mount: warning: /etc/mtab is not writable (e.g. read-only filesystem). It's possible that information reported by mount(8) is not up to date. For actual information about system mount points check the /proc/mounts file.
    [root@big-ip-1:ModuleNotLicensed:Active:Standalone] config ls -la /
    total 154 dr-xr-xr-x. 28 root root 1024 2017-01-11 16:12 . dr-xr-xr-x. 28 root root 1024 2017-01-11 16:12 .. -rw-r--r--. 1 root root 88 2017-01-11 16:13 1 -rw-r--r--. 1 root root 0 2017-01-11 16:12 .autofsck dr-xr-xr-x. 2 root root 4096 2017-01-10 18:55 bin dr-xr-xr-x. 6 root root 1024 2017-01-10 18:55 boot drwxr-xr-x. 2 root root 1024 2016-08-12 07:35 cgroup drwxr-xr-x. 2 root root 1024 2017-01-10 18:53 command drwxr-xr-x. 23 root root 4096 2017-04-17 15:40 config drwxrwxrwt. 2 root root 1024 2017-03-09 18:42 .config.tmp -r-xr-xr-x. 1 root root 2408 2016-08-12 07:24 CONTACTS -r-xr-xr-x. 1 root root 1100 2016-08-12 07:24 COPYRIGHT lrwxrwxrwx. 1 root root 19 2017-01-10 18:53 defaults -> /usr/share/defaults drwxr-xr-x. 18 root root 3800 2017-01-13 21:17 dev drwxr-xr-x. 102 root root 8192 2017-03-10 10:10 etc lrwxrwxrwx. 1 root root 19 2017-01-10 18:53 examples -> /usr/share/examples drwxr-xr-x. 6 root root 1024 2017-02-21 16:17 home drwxr-xr-x. 2 root root 1024 2016-08-12 07:20 hotfix -rw-r--r--. 1 root root 223 2017-01-11 16:13 HWINFO dr-xr-xr-x. 15 root root 9216 2017-01-10 18:55 lib drwxr-xr-x. 5 root root 8192 2017-01-10 18:53 lib64 drwx------. 2 root root 12288 2017-01-10 18:50 lost+found drwxr-xr-x. 2 root root 1024 2016-08-12 07:32 media drwxr-xr-x. 5 root root 1024 2017-01-11 03:26 mnt drwxr-xr-x. 7 root root 1024 2017-01-10 18:53 opt -rw-r--r--. 1 root root 0 2016-08-12 08:03 .permit.plymouthd -rw-r--r--. 1 root root 55 2017-01-10 11:02 PLATFORM -rw-r--r--. 1 root root 0 2016-08-12 08:03 .plymouthd.show_default_splash dr-xr-xr-x. 318 root root 0 2017-01-11 16:12 proc -rw-------. 1 root root 1024 2017-03-15 15:01 .rnd dr-x------. 3 root root 1024 2017-03-15 15:51 root dr-xr-xr-x. 3 root root 7168 2017-01-10 18:55 sbin drwxr-xr-x. 7 root root 0 2017-01-11 16:12 selinux lrwxrwxrwx. 1 root root 12 2017-01-10 18:53 service -> /var/service drwxr-xr-x. 27 root root 4096 2017-04-17 16:14 shared drwxr-xr-x. 2 root root 1024 2016-08-12 07:32 srv drwxr-xr-x. 13 root root 0 2017-01-11 16:12 sys -rw-r--r--. 1 root root 0 2016-08-12 08:03 .sysinit.run.plymouthd drwxrwxrwt. 5 root root 7168 2017-03-15 03:23 tmp lrwxrwxrwx. 1 root root 7 2017-01-10 18:54 ts -> /var/ts drwxr-xr-x. 18 root root 4096 2017-01-10 18:53 usr -rw-r--r--. 1 root root 0 2017-01-10 18:55 .vadc_fetch_keys drwxr-xr-x. 53 root root 4096 2017-01-11 16:14 var -r-xr-xr-x. 1 root root 1148 2016-08-12 07:24 VENDOR lrwxrwxrwx. 1 root root 11 2017-01-10 18:50 VERSION -> VERSION.LTM -rw-r--r--. 1 root root 0 2016-08-12 07:26 VERSION.ASM -rw-r--r--. 1 root root 197 2017-01-10 18:50 VERSION.LTM -rw-r--r--. 1 root root 25 2016-08-12 08:09 VERSION.WA -rw-r--r--. 1 root root 0 2016-08-12 08:31 VERSION.WOC [root@big-ip-1:ModuleNotLicensed:Active:Standalone] config
