PJ_47272's avatar
PJ_47272
May 06, 2013
11.3 VE Lab and APM
I am receiving the attached error in VE Lab edition trying to configure SmartAccess for my WebTop. I'm running HF5 on 11.3 VE. Is this not supported in VE? Seems like this is more like APM Lite so I was not sure if this would work but it appears to be available as an access policy in the APM. I am using the latest template (f5.citrix_xenapp_xendesktop.2012_06_27) for Citrix as well. Any help woul dbe appreciated.
JP
  • JP,
    The attachment did not come through, so I can't see the exact error you have - please try to repost.
  • I am not sure why but I keep getting the error "Editor not supported". Does IE9 or Chrome (I tried both) not work with the forums? Anyway, the error occurs *after* you select the SmartAccess policiy option and click Add item. Specific Error is:
    "An error "Error while loading access policy (Default item '/Common/Citrix-XenApp.app/citrix_act_citrix_smart_access' is not found)' has occurred on the server.
    Any ideas?
