dragonflymr
Jun 01, 201510.0.1 deleted pool configsync issue
I am looking for any clue why after deleting unused pool on Active ConfigSync can't be successfully performed. Any first hand experience, SOLs or other places to look for solution?
Piotr
- nitass
Employee
have you checked /var/log/ltm on both units? what did you get?
- dragonflymr
I have no access to device right now. I will post errors when it will be possible. Piotr
- nitass_89166
Noctilucent
- dragonflymr
- Samir_Jha_52506
Noctilucent
This is know issue. Please check this
- dragonflymr
Hi, Thanks for reference but I doubt it's related. In my case steps are different: 1. Verifying if pool is used (grep config files) 2. Delete pool 3. Try to do ConfigSync - error during sync. Can't tell what error as I have no access to device right now. So there is no delete/create sequence here as described in SOL. SOL is as well referencing 11.6-11.0, in my case it's 10.0.1 Piotr
