Dave_Pisarek's avatar
May 19, 2021
XFF and sleep
Recently I was asked about mitigating the below XFF header:
X-Forwarded-For: (select(0)from(select(sleep(5)))v)/*'+(select(0)from(select(sleep(5)))v)+'"+(select(0)from(select(sleep(5)))v)+"*/
Basically it is an injection to sleep the request.
The question was, can we enforce that the X-Forwarded-For header contains ip data only?
Working with LTM and ASM I was thinking either an irule or a customer attack signature to mitigate any requests where wording is in the XFF header.
Before I start testing different options, has anyone encountered and implemented any protection for this type of request?
  • Hi Dave,
    you can block this by enforcing Attack Signature ID 200000074 (SQL-INJ "end-quote select" (Headers)).
    Another approach could be to use an iRule or LTM Policy to scrub any XFF header from the HTTP Request. Unless there is a device in front of the BIG-IP that would insert such header, why would a client send a XFF header...
    KR
    Daniel
  • If you don't have ASM/Advanced WAF and would like to do this in an iRule, you could do a check to make sure the value(s) are at least numeric and then act accordingly on finding something else. For example:
    % set x (select(0)from(select(sleep(5)))v)/*'+(select(0)from(select(sleep(5)))v)+'"+(select(0)from(select(sleep(5)))v)+"*/
    % foreach ip $x {
      if { [string is integer [lindex [split $ip "."] 0]] } {
        puts "header ok"
      } else { puts "header not ok" }
    header not ok
    % set x 1.2.3.4
    1.2.3.4
    % foreach ip $x {
        puts "header ok"
    header ok
    Note that this is very rudimentary to show what's possible. If you want to verify actual valid IP addresses in the header, far more logic is required.
    • I took a different approach with an iRule. You can verify it the XFF header contains a valid IP address:
        if { [scan [HTTP::header "X-Forwarded-For"] %d.%d.%d.%d a b c d] == 4 && 0 <= $a && $a <= 255 && 0 <= $b && $b <= 255 && 0 <= $c && $c <= 255 && 0 <= $d && $d <= 255}  {
          #log local0. "Valid XFF Header: [HTTP::header "X-Forwarded-For"]"
          reject
          #log local0. "Invalid XFF Header: [HTTP::header "X-Forwarded-For"]"
      From my log:
      May 26 08:15:16 awaf.mydomain.de info tmm1[11286]: Rule /Common/rule_verify_xff <HTTP_REQUEST>: Invalid XFF Header: (select(0)from(select(sleep(5)))v)/*'+(select(0)from(select(sleep(5)))v)+'"+(select(0)from(select(sleep(5)))v)+"*/
      May 26 08:15:57 awaf.mydomain.de info tmm3[11286]: Rule /Common/rule_verify_xff <HTTP_REQUEST>: Invalid XFF Header: 10.200.200.1000
      May 26 08:16:06 awaf.mydomain.de info tmm2[11286]: Rule /Common/rule_verify_xff <HTTP_REQUEST>: Invalid XFF Header: 10.200.200.256
      May 26 08:16:26 awaf.mydomain.de info tmm2[11286]: Rule /Common/rule_verify_xff <HTTP_REQUEST>: Valid XFF Header: 10.200.200.254
      • JRahm's avatar
        JRahm
        Icon for Admin rankAdmin
        It's true that scan as written will validate a specific IP address, but it will not handle the case where an IP address is in the string with other characters, or in a list of IP addresses (as is sometimes the case with XFF), or finally, a valid IP address in a superset range where, in the case of network 10.10.10.0/23, the IP 10.10.10.255 is completely valid because the broadcast is 10.10.10.11.255. (Update...actually, we just need to validate that it is a possible IP address, not that it is valid in the context of a client network, so ignore this last point. And with that, just adding a foreach loop to your logic to handle multiple IP addresses might be good enough)
        That's why I stayed rudimentary, because the logic is a project since we don't have the full breadth of Tcl libraries available in iRules that have already solved this problem.
        Also, ASM/AdvWAF is the way to go here, if you have it. And if you don't, why not? :)
