X-Forwarded-For not working
VikashC
Cirrus
Cirrus
Hey,
I have one armed architecture and enabled SNAT in my environment. Now we have enabled X-Forwarded-For under http profile which attached on F5 virtual server. Somehow, it is not working. Any idea? If any thing missing from my end?
1 ACCEPTED SOLUTION
Hi  , have you done configuration on web server end? You need to do configuration on web server end also for extracting IP address from x-forwarded-for http header. I think, it seems to be missing here.
Below link gives information on the configuration to be done on web-server end.
https://support.f5.com/csp/article/K4816
Hope it solves your problem. Please keep us updated.
Mayur
3 REPLIES 3
Mayur
VikashC
Cirrus
Cirrus
​Oh I think, I missed it. Let me check provided link.
Thanks for your response.
VikashC
Cirrus
Cirrus
​Yo! It worked man. I did configuration at web server end and now it is working as expected.
Thank you again. Appreciate your help.
