Technical Forum
will the Native Java work on Firefox?
Carlos_Garibay_
Hello
I'm having issues using launching an RDP link resource through firefox.
**A browser plugin is required to use this site. This site is not currently allowed to install software. To continue, select one of the following options.
Allow plugins and continue with installation.
    Make sure your browser allows to install plugins from this site.
    Click here to continue with the installation.
Download and install the software manually.
    Click here to download and save a compressed file. This file contains a plugin for your browser.
    Uncompress the file, and move content of it into your browser plugins directory.
    Click here to restart the session.
Continue without allowing plugins or installing software.
Note that some or all functionality might be disabled if you select this option
Click here to continue**
I tried all options with no success
Any work a rounds or solutions?
Carlos
1 ACCEPTED SOLUTION
Brad_Parker_139
Nacreous
Nacreous
Have you tried using the java client rather than the native for RDP? You may have more luck. Remember it will have to be enabled the java client both in your RDP policy object and on the VIP itself.
15 REPLIES 15
Brad_Parker_139
Nacreous
Nacreous
Yes I did try java, but redirect printing does not work. I am using a SSL Certifcate signe by a 3rd party. I wonder if that has anything to do it with?
Also, have you installed the plug-in when prompted in FireFox?
yes, when I try to install I get " FIrefox has prevented this from installing an unverified ad on"
Ahh, the browsers are all starting to dislike plug-ins. So you will have to force FireFox to install and run the add-on. You can override the setting to enforce the add-on signing requirement by changing the preference xpinstall.signatures.required to false in the Firefox Configuration Editor (about:config page). I'm not sure when F5 is planning on or if they are planning on signing their plug-ins and get them added to the various browsers' allowed lists/stores.
Hello Brad,
and, How do it in Google Chrome? I did this in Firefox, but I think the plugin to download is corrupted 😞
Regards,
Oscar
That worked Thanks alot Brad for your time
Most welcome.
Brad_Parker
Cirrus
Cirrus
Most welcome.
