saidshow's avatar
saidshow
Icon for Cirrus rankCirrus
Sep 12, 2019
Will changing to HTTP/2 impact ASM policies?
Hi All,
We currently have a large number of ASM policies in place and have recently resumed discussions on enabling HTTP/2 on the F5s.
Since HTTP/2 operates quite differently to HTTP/1.1 will the change have any impact on the existing ASM policies? eg. WIll they continue to detect malicious requests, illegal characters etc?
Thank you.
  • JG's avatar
    JG
    This posting "https://devcentral.f5.com/s/question/0D51T00006j3RBqSAM/asm-and-http2-errspdyprotocolerror-issue" would suggest that the combination is indeed supported.
  • Thanks  , looking at that link, it's suggested that HTTP/2 is better supported with ASM in Version 13.1.0.7 which i certainly part of the information I needed.
    Additionally, I want to confirm that existing ASM policies will continue to block and allow the same traffic once HTTP/2 is enabled on the F5, on the servers and modifications made on the web app to better support HTTP/2.
