Technical Forum
Will a port specific VIP override an ANY VIP?
Stuewe
I have a service running that uses a range of ports both TCP and UDP.  So I had created 2 VIPs one for TCP any and one for UDP any.    Now, I need to point a new range of ports to a new pool.  I'm trying to use the VIP IP address.  If I create a new port-specific VIP will it take priority over the ANY VIP that already exists?
1 ACCEPTED SOLUTION
Hi @Stuewe , You're exactly right, the most specific VIPs will be selected first. See this guide for a detailed breakdown and examples of different scenarios.
https://my.f5.com/manage/s/article/K14800
1 REPLY 1
