Hooni_L's avatar
Hooni_L
Icon for Cirrus rankCirrus
Jan 15, 2023
Solved
Why it does not switching secondary ip address on azure when failover???
Device 1 : #1 (Active)
Device 2 : #2 (Standby)
I performed a failover.
Active device running Failover script, but it fail.
There seems to be an abnormal operation on the secondary IP.
to assign both equipment 1 and 2 to equipment NIC 2.
I need reset the failover extention or get metadate(azure) information.
How can I?
  • Hi JRahm
    I couldn't find a solution from the data you gave me.
    but I will try the following measures.
    Clear the statusdb file:
    1. In the Azure portal, go into the storage account ending with 'data000'
    2. Go to containers, "failover" container
    3. Delete statusdb file
