22-Sep-2022 11:40
I want to write and iRule to key on a source IP and log the pre-shared master keys:
when CLIENT_ACCEPTED {
if { [IP::addr [IP::client_addr] equals 10.10.10.10] } {
when CLIENTSSL_HANDSHAKE {
log local0. "[TCP::client_port] :: RSA Session-ID:[SSL::sessionid] Master-Key:[SSL::sessionsecret]"
when SERVERSSL_HANDSHAKE {
Solved! Go to Solution.
22-Sep-2022 12:26 - edited 22-Sep-2022 12:28
Can't have iRule events nested inside other events.
22-Sep-2022 13:26
Just do this in the server side event to see what the client IP is:
log local0. "client IP: [IP::client_addr]"
22-Sep-2022 12:43
Thank you so much Kevin, although for my SERVERSSL_HANDSHAKE i think i should use my self IP? Unless the iRule only looks at the cs-client-addr?
22-Sep-2022 12:51
You're saying, if the client source address is 10.10.10.10, log the client side session-id and server side session-id.
[IP::client_addr] is still the client source, even on the server side.
22-Sep-2022 13:24
I tested it out and the client side worked, however the serverside did not. So i think I'll update the serverside with the self IP and see what i get. Thanks again Kevin!
22-Sep-2022 13:26
