Technical Forum
Webtop to BigIP mgmt console being denied after update to 12.1.3
TLL_91858
Cirrus
Cirrus
Running on 12.1.2 (HA) a full webtop portal access for management tools. I've got my BigIP management consoles on the Webtop. Opening BigIP mgmt console when both units are at 12.1.2, all is well. I upgraded one unit of the HA pair to 12.1.3, now I get this:
* 1.2 webtop (Active), going to 12.1.3 works fine
* 1.3 webtop (Active), going to 12.1.2 works fine
* 1.3 webtop (Active), going to 12.1.3 fails with
"You do not have permission to access this page. Access was denied by an access control list. "
Checking session data in the APM shows a Kerberos error that access to [unitID] "rejected because it points to a reserved address."
Anyone seen this yet?
Tom
1 REPLY 1
Palo_Palacios_3
I have the same problem.
Any workaround or solution?
Thanks. Regards
