Technical Forum
Custom Alert Banner
WAF behind Internal Load Balancer in Azure
AG
Hello team ,
I have a query related to WAF
We have a VNET in Azure
There are two entries from the Internet - one is Internet facing firewall which is checkpoint cluster for all north-south traffic . There is an Azure Load Balancer external in front of it
The other entry is via SRX also internet facing where all our VPN tunnels(from on prem sites) will be terminating
Question is can we use a common Internal Load Balancer for both these firewalls
and then place a F5 WAF after the common Internal Load Balancer .
or cant we directly use F5 WAF as Internal Load Balancer instead of using Azure Internal LB
1 REPLY 1
AG
Anyone ?
