11-Sep-2019 05:48
From the PCI audit I get the following: Vulnerability SSL Medium Strength Cipher Suites Supported
Currently the following is configured:
list sys httpd
sys httpd {
auth-pam-idle-timeout 2400
ssl-ciphersuite HIGH:!ADH
ssl-protocol TLSv1.2
Would it be correct to change this to
modify /sys httpd ssl-ciphersuite 'ALL:!ADH:!EXPORT:!eNULL:!MD5:!DES:!SSLv2:-TLSv1:-SSLv3:RC4-SHA'
or do I need other settings ?
11-Sep-2019 06:01
I suppose it's for mgmt service:
you have many example here:
https://httpd.apache.org/docs/trunk/ssl/ssl_howto.html
How to create an SSL server that only accepts strong encryption?
SSLCipherSuite ECDHE-ECDSA-AES256-GCM-SHA384:ECDHE-RSA-AES256-GCM-SHA384:ECDHE-ECDSA-CHACHA20-POLY1305:ECDHE-RSA-CHACHA20-POLY1305:ECDHE-ECDSA-AES128-GCM-SHA256:ECDHE-RSA-AES128-GCM-SHA256:ECDHE-ECDSA-AES256-SHA384:ECDHE-RSA-AES256-SHA384:ECDHE-ECDSA-AES128-SHA256:ECDHE-RSA-AES128-SHA256
How to create a server that accepts many types of encryption in general, but requires strong encryption to access a particular URL?
you can also refine as you go...
You confirm that it's for the management interface?
regards
11-Sep-2019 06:18
Hi, I confirm it is the management interface so would the following configuration solve the problem of Medium Strength Cipher Suites " modify /sys httpd ssl-ciphersuite 'ALL:!ADH:!EXPORT:!eNULL:!MD5:!DES:!SSLv2:-TLSv1:-SSLv3:RC4-SHA' OR modify /sys httpd ssl-ciphersuite HIGH OR .... something else.
I want the highest (strongest ciphersuite/level of security.
11-Sep-2019 06:52
There is a solution, get rid of all the low and medium level ciphers from apache conf file.
Try this first, it can fix your problem:
TLSv1.2+HIGH:!aNULL:!eNULL
Keep me in touch.
18-Oct-2019 00:04
TLSv1.2+HIGH:!aNULL:!eNULL didn't help, I know configured
modify /sys httpd ssl-ciphersuite "ECDHE-RSA-AES128-GCM-SHA256:ECDHE-RSA-AES256-GCM-SHA384:ECDHE-RSA-AES128-SHA:ECDHE-RSA-AES256-SHA:ECDHE-RSA-AES128-SHA256:ECDHE-RSA-AES256-SHA384:ECDHE-ECDSA-AES128-GCM-SHA256:ECDHE-ECDSA-AES256-GCM-SHA384:ECDHE-ECDSA-AES128-SHA:ECDHE-ECDSA-AES256-SHA:ECDHE-ECDSA-AES128-SHA256:ECDHE-ECDSA-AES256-SHA384:AES128-GCM-SHA256:AES256-GCM-SHA384:AES128-SHA:AES256-SHA:AES128-SHA256:AES256-SHA256"
