j_kevin's avatar
j_kevin
Apr 10, 2020
VPN BIG-IP Edge client : difference between dynamic and static configuration ?
I have a VPN connection between a Windows client and a BIGIP v15.
I am using BIGIP Edge client, with network access.
According to this document : https://support.f5.com/csp/article/K24416258
"Edge client connects to the APM Virtual Server and downloads the configuration".
1. What are precisely the features downloaded ?
2. Does this mean that the msi file installed on Windows client provides static configuration ?
3. May the dynamic configuration (1.) overwrite the static configuration (2.) ?
