Technical Forum
Vpn Always connected mode
Miguel_1400
Hello,
We have the Big-ip edge client with the Always Connected mode and I would like to know if it's possible to add some exlcusion to allow explicit IP destination to do not pass througt the VPN SSL ? I know it's possible to add exclusion list but this one is only valable when the big-ip edge client isn't already connected and is in block mode right ?
Is it possible in full tunneling or only on split ?
Regards,
3 REPLIES 3
Paulius
MVP
MVP
@Miguel_1400 This would only be possible with split tunnel.
Hello  @Paulius
Thank you for your reply 🙂
Can I configure my Big-IP edge client on Always Connected Mode and use Split tunneling ? Can I configure an Wildcard on the Network acces so all traffic would go thought the VPN SSL and Exclude some IPv4 to pass thougt the local user gateway ?
If yes, this kind of configuration still "best practice" ou it's " bricolage" ?
Regards,
LiefZimmerman
Community Manager
Community Manager
@Miguel_1400 - If your post was solved it would be helpful to the community to select *Accept As Solution*.
This helps future readers find answers more quickly and confirms the efforts of those who helped.
Thanks for being part of our community.
Lief
