Manu99's avatar
Manu99
Nov 09, 2025
Solved
F5OS (rseries 2800) in transparent mode
I am trying to configure F5 BIG-IP (tenant) in transparent mode on F50S.
Someone already did it please ?
I didn't use F5OS before.
  • It's okay now I just need to choose the portgroup that I need and set up its profile. iAfter that I can use those interfaces in my tenant.
  • Near heard of this to be honest an you have not provided a lot of info what is the "transparent" mode option means for you? Like vcmp there are configured/provisioned and deployed modes but this was the same with F5 vCMP and and the first 2 modes F5 does not process client traffic so they seem not the right thing. Maybe see as well https://techdocs.f5.com/en-us/f5os-a-1-8-3/f5-rseries-systems-administration-configuration/title-network-settings.html as if you mean vWire option that was there in iSeries as well.
    I F5 AWAF/ASM has transparent mode but has nothing to do with F5OS itself as this feature is there in a long time.
  • I think it's okay. By default , the interfaces are in a group so I just need to remove it and define it a profile before assign it to a tenant.
    This is my comprehension !
