23-Jun-2020 05:22
I am trying to configure multiple vlans for virtual having their gateway for vlans hosted on switch virtual interface. I wanted to route the traffic from each virtual vlan to the backend members through their specific gateway. Is there a way to declare the default gateway individually for each specific vlan.
Whenever I am trying to add the default route for vlans configured on the LTM , it give me a message saying Implied Route is there. I am not sure I was not able to find out the route by which the self ip address will be communicating to the pool members.
vlan 123 -- 10.1.10/24 -- 10.1.12
vlan 234 -- 10.1.2.0/24 --10.1.2.2
vlan 456 -- 10.1.3.0/24 --10.1.3.2
I wanted to point the virtual subnets specifically to their default gateway but I am not able to do so , is there a way
23-Jun-2020 08:46
Where you are using static or default routes then you can only create a single default route, though you can create multiple static routes via each subnet. For instance, if you have pool members in the range 10.2.0.0/16 via vlan 123 then you can add that route but you an't have multiple default routes. Of course you can use different route domains so that you have separated networks and routing, in which case you have a route per RD. You can also use dynamic routing if you want to have more complex routing setup without having to maintain static routes. You can also set the nexthop via iRule.
Regarding incoming traffic, autolasthop means that it will always go back to the device from which it arrived so you won't need those routes. It is common to just have a default route to enable the BIG-IP to be able to get to the pool members.
24-Jun-2020 02:54
So my doubt here is the monitoring will be done via the self IP of Vlan for which I have declared the default route.
Is there a concept of multiple default gateway , i tried to add the default gateway in a pool and then point the same through the default route but I am confused how does the tmm decides which Self IP will be communicating to the backend pool members for monitoring purpose
24-Jun-2020 03:44
24-Jun-2020 08:45
So , it means we cannot have multiple default gateway for f5 which can be used specifically for the vlan configured on for virtuals -listeners and then the self ip of each vlan tries to communicate to the backend pool members via the default gateway configured specifically for that vlan on the next hop of switch virtual interface.
I was trying to configure separate routes for each of the vlan but then it gives me a message of Implied Route is already present for that vlan . So I am wondering the backend traffic will still be monitored from only one vlan rather than each vlan specifically. Also , one more suggetion , if I create multiple vlans for virtual but the backend traffic passes through only one vlan default route will that create an asymetric routing , actually i am messed up with this architecture
24-Jun-2020 08:51
24-Jun-2020 09:27
I wanted to add a static route for all the vlans rather than the default gateway pointing to one of the vlans , I tried to add the default gateways in a pool with having all the member of the vlans added in a pool and monitored by Gateway ICMP monitor and adding them as default gateway , but how does that takes preference from tmm also the current architecture is we have only one vlan declared on the f5 with its self ip and the rest of the subnets are just pointed to the default gateway of that vlan on the switch virtual interface.
Moreover , i wanted to change this structure of having all the traffic traversing through one vlan to multiple vlans for virtuals.
24-Jun-2020 09:33
